Tweaks by WoP
Posted: 11 Jan 2012 00:42
nvidea settings:
Antisotrope Filter = Aplication Control, Antialiasing Settings = Aplication Control, Antialiasing Gammer - Corection = On
Antialiasing Mod = Aplication Control, Antialiasing Transparence = Multisampling, CUDA GPU`s = all, Trippel Buffer = on
Max Renderet Picture = 3, Multy Display option = Single Display, Texturefiltering - Antisotrope = Out,
Texturefiltering - negative LOD Bias = Clamp, Texturefiltering - Trilineare Optimise = On, Threaded- Optimise = Auto
Vertical Synconisation = force alway off.
ingame settings:
Resulution : 1280 * 1024, Model-Ditail = High, Building-Ditail = Low ( needs the most power), Land-Ditail = High,
Trees = Low (needs the most pover), Visual Efects = Medium ( to see the enemy plane, when i open fire Grin), Texturequalety = High
Antialiasing = 0 (so the cons dont dissepire when you get closer), Anti Epelepsi Filter = Off, SSAO = Off, VSYNC = OFF, Damage looking = High
How mutch Buildings = Low (needs the most power), Land-Shading = High, Grass = On, Shadow = On, Streets = On
Win 7 settings:
go to Control Panel \ All Control Panel items \ Power Options: and put the option to highlevel, not to energie save mod.
my settings there are 100% CPU usage at low and at High, so my CPU runs all the time at 100%.
rightclick on steamicon and under compatibility put a mark in where win 7 is allowed to make a low desktopresolution when playing CoD.
Download Gamebooster 3 and use it, helps me a lot.
config tuning with steamcloud enabled
to see the contacts better and that the dont dissepire when you come closer go to your config, search for the part [core]
and there for the MeshShowLod=0 file and change it to 1.
to run it with steamcloud you need to make it before you run the game and steam and in both configs (steamfolder and 1C folder)
than start the game, go to windows check if it is in both configs, if not make it again (game still running) and than close the game and let steam synconisite with steam. check both config again if its there everything is ok now when not try it again.
http://www.warbirdsofprey.org/index.php?topic=11035.0
Re: Tweaks by WoP
Posted: 11 Jan 2012 19:24
Ajustes no painel de controle - Nvidea:
CUDA GPU`s = All
Tripple Buffer = On
Texturefiltering - Negative
LOD Bias = Clamp
Vertical Syncronisation = Force alway off.
Ajustes no jogo:
Resulution : 1280 x 1024
Model-Detail = High
Building-Detail = Low (exige potência da VGA)
Land-Ditail = High
Trees = Low (exige potência da VGA)
Visual Efects = Medium (para ver o avião inimigo, ao atirar nele)
Texture quality = High
Antialiasing = 0 (assin o ícone do inimigo não desaparece (momentaneamente) quando perto ~2KM.)
SSAO = Off
VSYNC = OFF
Damage effects = High
Buildings (quantidade) = Low (exige potência da VGA)
Land-Shading = High
Grass = On
Shadow = On
Streets = On
Ajustes no Windows 7:
Vá no Painel de Controle > Todos os itens do Painel de Controle > Opções de energia:
Coloque a opção em alto nível, não em "economizar energia".
Meus ajustes são 100% de uso da CPU em Baixo e Alto, então minha CPU funciona sempre a 100%.
Clique com o botão direiro do mouse (RMB) sobre o ícone do STEAM e em "compatibility" (compatibilidade) marque a caixa "Permitir ao Windows 7 colocar o desktop em baixa resolução ao jogar o CloD".
Baixe o "Gamebooster 3" e use, ajuda muito.
Ajustes as configurações com o STEAM CLOUD habilitado.
Para ver melhor os contatos (aviões) e para que não desaparecem quando chegam perto (~2 KM) va no "conf.ini" (do CloD) e localize a parte
[core]
E nela mude o MeshShowLod=0 para =1.
Para executar isto com o STEAM CLOUD é preciso fazer os ajustes antes de rodar o jogo e o STEAM nos dois "conf.ini" (na pasta Steam - em Arquivos de programas e na pasta 1C Soft Club - em meus documentos).
Então inicie o jogo, alterne para o Windows e verifique ambos os "conf.ini", se não estiveram alterados, ajuste novamente (com o jogo sendo executado em segundo plano) e então feche o jogo e deixe sinconizar os arquivos com o STEAM.
Novamente cheque os "conf.ini" para ver se esta tudo OK e se não tente novamente. :P
Obs (by me): note que estas configurações trocam qualidade visual - ao desabilitar o "Antialising" no jogo e nas configurações da VGA (Nvidea) e o "Wait for VSync" por "gameplay" (ver melhor o ícone do inimigo).
Troca até mesmo desempenho por "gameplay"(ver melhor o inimigo) ao modificar o MeshShowLod= para 1, pois é sabido que isto impacta negativamente o FPS.
Re: Tweaks by WoP
Posted: 11 Jan 2012 21:50
by komet163
Fiz algumas das modificações, menos é claro o que foi citado pelo Sokol. Mas o meu tempo disponível pra testar é que não existe rsssss.
Na realidade tenho voado pouco, espero fazer isso no próximo fim de semana.
Abraços pra todos.
