Lock On - Flamings Clifs 2.0 upgrate.
Anunciado (ainda não lançado), novidades:
* Runs under DirectX 9C
* Improved Mission Editor with trigger system
* New terrain area to include much of Georgia. This will be same map as used in DCS: Blacks Shark. As such the Crimea has been replaced with the addition of Georgia.
* More detailed terrain to include more ground objects, larger forests, and higher resolution elevation data
* Improved clouds
* High resolution airfield textures
* Improved multiplayer system with embedded game browser
* More robust online cheating prevention
* New and improved menu system
* Numerous new, highly detailed ground units including infantry
* Improved flight performance for player-controlled aircraft
* Improved flight models for all artificial intelligence (AI) controlled aircraft
* New, more realistic G-tolerance modeling
* Limited 6 DOF cockpits that move up, down and sideways according to maneuvering
* New and highly-detailed Su-25 model
* Advanced ballistics are implemented for all flyable aircraft, including ricochets of AP rounds
* F-15C locked target IFF indication
* More realistic ranges, seeker guidance and fuzes for air-to-air missiles
* More realistic electronic countermeasure operation and performance
* New and improved sound engine
* New radio message voice-overs
http://www.simhq.com/_air13/air_434a.html
Detalhe interessante, sera compativel online com o DCS:Black Shark, por exemplo pode-se jogar uma coop um piloto no BS e outro no LOMAC.
* Improved clouds
- 03_Vingador
Re: Lock On - Flamings Clifs 2.0 upgrate.
Alem da integração com o DCS:Black Shark (Ka-50), o que permitira que pilotos nos dois sim participem de uma mesma missão cooperativa ou H2H online, o FC 2.0 tera terreno, editor de missões, modo de vôo da IA, objetos 3D, IA e multiplayer aperfeiçoados. As aeronoves incluidadas nesta atualização são:
• Su-25 (com novo modelo 3D)
http://forums.eagle.ru/showthread.php?t=50249
• Su-25T
• A-10A
• Su-27
• Su-33
• MiG-29A
• MiG-29C
• F-15C
Várias novas missões e campanhas serão incluidas nesta atualização.
O preço será U$ 29,99, e atualizará tanto o Lock On como o Flaming Cliffs para o
LOCK ON: FLAMING CLIFFS 2.0
Teaser:
• Su-25T
• A-10A
• Su-27
• Su-33
• MiG-29A
• MiG-29C
• F-15C
Teaser:
- 32_Mariocar
- Engrenado
Muito legal, o problema é o curso de pós-graduação que você tem que fazer para voar nesse simulador.
Bom dia Sokol.
Tenho 2 dúvidas e seria muito grato se puder respondê-las:
1 - Possuo apenas o LOMAC. Para se jogar o FC2 necessito do FC ou apenas com esta versão já poderei jogar sem problemas ?
2 - Ele precisará de um pc melhor configurado ? (No caso se ele vai muito mais pesado que o LOMAC)
Abs
Abs
Respondendo:
1. Segundo o proprio site, o FC 2.0 atualizará o Lomac e o FC para o 2.0, portanto se tu tem o lomac tu vai conseguir atualizar sem problema. (isso gerou bastante protesto de quem tem o FC)
2. Seguindo a logica, o FC 2.0 deve se igualar com o BS em termos de peso, ou seja vai ser mais pesado que o lomac e o FC, se bem que nada que um bom tweak não resolva.
Obrigado Madmax !
Não entendí?????="MadMax"]Respondendo:
DOC
Acho que é assim...DocFlyer wrote:Não entendí?????![]()
DOC
Os caras que pagaram pelo Lomac e depois pagaram pelo FC estão achando injusto terem que pagar pelo 2.0 a mesma quantia de quem não tem o FC, ou seja, estão com dor de cotovelo.
É exatamente isso ai Santo.
- 41_Tche-Loko
- Manicaca
Para quem não tem Lomac e/ou FC, o que precisa comprar para fazer o upgrade para o Lock On - Flamings Clifs 2.0?
Tche-Loko
Precisa comprar o Lock On:Modern Air Combat (já que o Flaming Clifs "1" é tambem um ad-on para ele).
Esta 17,50 U$ (CD-Box) no E-shop da DCS:
http://lockon.co.uk/index.php?end_pos=1322&scr=shop
Ou no eBay:
http://video-games.shop.ebay.com/Games- ... pos=&gbr=1
BTW - Os "FlamingClifistas" estão chorando a toa. Veja quantas versões do IL-2 foram vendidas:
IL-2 Sturmovik
Forgothen Battles
Ace Expansion Pack
Pacific Fighters
Complet Colection
Pe-2
Sturmovik over Manchuria
IL-2 Sturmovik 1946
Isso se não esqueci algum.
Ou no eBay:
IL-2 Sturmovik
Forgothen Battles
Ace Expansion Pack
Pacific Fighters
Complet Colection
Pe-2
IL-2 Sturmovik 1946
É, lá vou eu novamente
Tenho o LockOn, FC, BS e agora tenho de comprar mais essa.
Pô, ao menos no IL-2 foi relativamente acumulativo.
Por isso a sacanagem.
DOC
Sokol,
só pra lembra, dá uma olhadinha no meu post sobre a compra do Saitek
Obrigado
DOC
Sokol,
Obrigado
Heads up: Já esta a venda - via download.
FAQ = http://forums.eagle.ru/showpost.php?p=7 ... ostcount=2Recommended system requirements: Windows XP, Vista or 7, CPU Intel Core 2 Duo or AMD X2; RAM 3 GB; video card with 512 MB RAM (ATI Radeon HD4850+ or nVidia GF8800+), compatible with DirectX 9; 5 GB of HDD space; sound card; keyboard and mouse; and joystick.
Aproveitem, porque novidade no genero (simulação) agora só (e se) quando sair o SoW:BoB...Q: Is it true that bird ingestion has been added?
A: Yes, but it can be set on or off with .LUA setting.
Comprei o meu e o instalo nesse momento.
Ao que parece será "Legendary".
