B17s enganchadas.
Papos e avisos genéricos para a comunidade simuleira.
B17s enganchadas.
Estória interessante. Resumidamente, tentando manter formação sob ataque de caças alemães uma B17 colidiu contra o fundo da que ia acima, com a torre inferiores de uma e a superior de outra penetrando na fuselagem do outro avião, resultou nos dois solidamente enganchados, continuando a voar como um "B17 biplano de 8 motores" por algum tempo, com o artilheiro da ball turrent do avião superior preso dentro da torre esmagada.
. "Piggyback Hero
.... He won the Distinguished Flying Cross and the Purple Heart all in one fell swoop in the skies over Germany on December 31, 1944.
Fell swoop indeed. Capt. Glenn Rojohn, of the 8th Air Force's 100th Bomb Group, was flying his B-17G Flying Fortress bomber on a raid over Hamburg. His formation had braved heavy flak to drop their bombs, then turned 180 degrees to head out over the North Sea. They had finally turned northwest, headed back to England, when they were jumped by German fighters at 22,000 feet. The Messerschmitt Me-109s pressed their attack so closely that Capt. Rojohn could see the faces of the German pilots.
He and other pilots fought to remain in formation so they could use each other's guns to defend the group. Rojohn saw a B-17 ahead of him burst into flames and slide sickeningly toward the earth. He gunned his ship forward to fill in the gap. He felt a huge impact. The big bomber shuddered, felt suddenly very heavy and began losing altitude. Rojohn grasped almost immediately that he had collided with another plane. A B-17 below him, piloted by Lt. William G. McNab, had slammed the top of its fuselage into the bottom of Rojohn's. The top turret gun of McNab's plane was now locked in the belly of Rojohn's plane and the ball turret in the belly of Rojohn's had smashed through the top of McNab's. The two bombers were almost perfectly aligned - the tail of the lower plane was slightly to the left of Rojohn's tailpiece. They were stuck together, as a crewman later recalled, "like mating dragon flies."
No one will ever know exactly how it happened. Perhaps both pilots had moved instinctively to fill the same gap in formation. Perhaps McNab's plane had hit an air pocket. Three of the engines on the bottom plane were still running, as were all four of Rojohn's. The fourth engine on the lower bomber was on fire and the flames were spreading to the rest of the aircraft. The two were losing altitude quickly. Rojohn tried several times to gun his engines and break free of the other plane. The two were inextricably locked together. Fearing a fire, Rojohn cuts his engines and rang the bailout bell. If his crew had any chance of parachuting, he h ad to keep the plane under control somehow.
The ball turret, hanging below the belly of the B-17, was considered by many to be a death trap - the worst station on the bomber. In this case, both ball turrets figured in a swift and terrible drama of life and death. Staff Sgt. Edward L. Woodall, Jr., in the ball turret of the lower bomber, had felt the impact of the collision above him and saw shards of metal drop past him. Worse, he realized both electrical and hydraulic power was gone.
Remembering escape drills, he grabbed the handcrank, released the clutch and cranked the turret and its guns until they were straight down, then turned and climbed out the back of the turret up into the fuselage. Once inside the plane's belly Woodall saw a chilling sight, the ball turret of the other bomber protruding through the top of the fuselage. In that turret, hopelessly trapped, was Staff Sgt. Joseph Russo. Several crewmembers on Rojohn's plane tried frantically to crank Russo's turret around so he could escape. But, jammed into the fuselage of the lower plane, the turret would not budge.
Aware of his plight, but possibly unaware that his voice was going out over the intercom of his plane, Sgt. Russo began reciting his Hail Marys.
Up in the cockpit, Capt. Rojohn and his co-pilot, 2nd Lt. William G. Leek, Jr., had propped their feet against the instrument panel so they could pull back on their controls with all their strength, trying to prevent their plane from going into a spinning dive that would prevent the crew from jumping out. Capt. Rojohn motioned left and the two managed to wheel the grotesque, collision-born hybrid of a plane back toward the German coast. Leek felt like he was intruding on Sgt. Russo as his prayers crackled over the radio, so he pulled off his flying helmet with its earphones. Rojohn, immediately grasping that crew could not exit from the bottom of his plane, ordered his top turret gunner and his radio operator, Tech Sgts. Orville Elkin and Edward G. Neuhaus, to make their way to the back of the fuselage and out the waist door behind the left wing. Then he got his navigator, 2nd Lt. Robert Washington, and his bombardier, Sgt. James Shirley to follow them. As Rojohn and Leek somehow held the plane steady, these four men, as well as waist gunner Sgt. Roy Little and tail gunner Staff Sgt. Francis Chase were able to bail out.
Now the plane locked below them was aflame. Fire poured over Rojohn's left wing. He could feel the heat from the plane below and hear the sound of .50 caliber machinegun ammunition "cooking off" in the flames. Capt. Rojohn ordered Lieut. Leek to bail out. Leek knew that without him helping keep the controls back, the plane would drop in a flaming spiral and the centrifugal force would prevent Rojohn from bailing. He refused the order.
Meanwhile, German soldiers and civilians on the ground that afternoon looked up in wonder. Some of them thought they were seeing a new Allied secret weapon - a strange eight-engine double bomber. But anti-aircraft gunners on the North Sea coastal island of Wangerooge had seen the collision. A German battery captain wrote in his logbook at 12:47 p.m.: "Two fortresses collided in a formation in the NE. The planes flew hooked together and flew 20 miles south. The two planes were unable to fight anymore. The crash could be awaited so I stopped the firing at these two planes."
Suspended in his parachute in the cold December sky, Bob Washington watched with deadly fascination as the mated bombers, trailing black smoke, fell to earth about three miles away, their downward trip ending in an ugly boiling blossom of fire. In the cockpit Rojohn and Leek held grimly to the controls trying to ride a falling rock. Leek tersely recalled, "The ground came up faster and faster. Praying was allowed. We gave it one last effort and slammed into the ground."
The McNab plane on the bottom exploded, vaulting the other B-17 upward and forward. It hit the ground and slid along until its left wing slammed through a wooden building and the smoldering mass of aluminum came to a stop. Rojohn and Leek were still seated in their cockpit. The nose of the plane was relatively intact, but everything from the B-17's massive wings back was destroyed. They looked at each other incredulously. Neither was badly injured.
Movies have nothing on reality. Still perhaps in shock, Leek crawled out through a huge hole behind the cockpit, felt for the familiar pack in his uniform pocket and pulled out a cigarette. He placed it in his mouth and was about to light it. Then he noticed a young German soldier pointing a rifle at him. The soldier looked scared and annoyed. He grabbed the cigarette out of Leek's mouth and pointed down to the gasoline pouring out over the wing from a ruptured fuel tank.
Two of the six men who parachuted from Rojohn's plane did not survive the jump. But the other four and, amazingly, four men from the other bomber, including ball turret gunner Woodall, survived. All were taken prisoner. Several of them were interrogated at length h by the Germans until they were satisfied that what had crashed was not a new American secret weapon.
